rough idle, dies if not in motion
185,000 MILES • 4.2L • V6 • RWD • AUTOMATIC
JPTOOXES
Over night my 2000 e150 van went from smooth to wont hardly idle if in gear and dies at stop light unless its put in neutral and gas pedal is fluttered. Please help.
Mar 18, 2016 at 9:52 PM
HMAC300
  • 48,601 POSTS
check for a vacuum leak and clean throttle plate on both sides and iac hole with choke cleaner. if it continues scan for codes and check fuel pressure with a gauge.
Mar 19, 2016 at 9:18 AM
  • 55,694 POSTS
Here is a guide that will help you find the vacuum leak
and a video
https://www.youtube.com/watch?v=xN5pcM-5bso
Also, is black smoke coming from the exhaust pipe?
Please let us know what you find
Mar 19, 2016 at 1:52 PM
