rough idle, cuts out while driving
159,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
MCCORDMICHAEL
  • 5 POSTS
Replaced, MAF sensor, Ignition coil, crank sensor, coil brick, coil unit, plugs and wires. Where is the coolant sensor located
Dec 27, 2015 at 1:51 AM
the coolant sensor is located by the thermostat housing. it has a 2 wire connector and screws into the manifold.
Dec 27, 2015 at 1:57 AM
MCCORDMICHAEL
  • 5 POSTS
Thanks!! How may I ask how to may to replace
Dec 27, 2015 at 2:44 AM
remove the connector, use a 3/4 wrench or socket to remove.
Dec 27, 2015 at 2:51 AM
MCCORDMICHAEL
  • 5 POSTS
THANKS!!! Have a great day
Dec 27, 2015 at 3:01 AM
you as well
Dec 27, 2015 at 3:02 AM
CJ MEDEVAC
  • 11,000 POSTS
DIFFERENT GUY
ON VACATION?-MAYBE FOR A WEEK?-IN YANKEELAND (CROGAN, NY)-IF YOU WOULD CALL IT THAT, IN SMALL HOUSE FULL OF SEVEN GRAND-MONSTERS (AND MANY MORE ADULTS???)-ON A BORROWED COMPUTER
"MY STUFF" IS STILL ON MY COMPUTER DOWN THERE IN GOOD OLE DIXIE
LET'S LET THE VEHICLE GET STONE COLD, THIS IS WHAT YOU ARE CHANGING IN THE LINK BELOW
http://shop.advanceautoparts.com/p/factory-air-coolant-temp-sensor-switch-36403/5899370-P?searchTerm=coolant+temperature+sensor
ROY ALREADY GAVE YOU THE LOCATION
HAVE THE OTHER ONE READY, AND YOU WON'T LOSE MUCH RADIATOR JUICE DURING THE SWITCH
A WRENCH IS PROBABLY ALL YOU WILL NEED FOR THE SENSOR
THE MEDIC
Dec 27, 2015 at 3:09 AM
