Rough Idle - Check Engine Light
204,000 MILES
UPMM019
  • 217 POSTS
I recently bought a 2001 Chevy Suburban 1500 LT 4WD with 204K miles on it.
the check engine light is on and had one of the auto parts store check the codes.
The first is Cyl 2 Misfires, EGR Cont Circut Perf, o2 sensor bank 2 sens 1 - that is what I was given.. not sure if that is short hand or not.....
That said, what can I do as a layperson to look into troubleshoot these issues.
Regarding the codes they were reset and tripped again.
the other thing that is noticeable is that the exhaust is really black as if it is running really rich.
Oct 9, 2013 at 8:12 AM
JDL
  • 16,098 POSTS
If you haven't given it a tune-up recently, give it a tune-up. 02 sensors are part of a tune-up. As far as cylinder number 2, check fuel--spark and compression on that cylinder.
Oct 9, 2013 at 8:28 AM
JDL
  • 16,098 POSTS
Just to add, can you give us the actual code #? What is the engine litre size? For cylinder #2 misfire, it should be p0302. Our database doesn't even list that code?
Oct 9, 2013 at 8:46 AM
UPMM019
  • 217 POSTS
I actually didn't get the code myself. I had a buddy bring it to a car part place and they read the code.
Like I said I just bought it so I have no clue if and when if it ever had a tune up.
If a tune up is step one what should that all entail?
Plugs, and what else? Is this something a layperson can do or does it need to be done by a shop with the diagnostics?
Oct 9, 2013 at 9:40 AM
JDL
  • 16,098 POSTS
Spark plugs--spark plug wires--dis. cap and rotor where applicable. Check or change filters, air and fuel. With the fuel filter make sure no pressure on the system before taking any fuel lines loose. Check all fluids. Like I said 02 sensors are part of a tune-up. Use a gage and check fuel pressure. I'm sure I'm leaving something out.
Make sure all the lites work front and rear/ turn signals--brake lites--tail lamps--tag lite. Make sure the horn works. Check the air in the tires.
What's engine litre size?
Oct 9, 2013 at 9:54 AM
UPMM019
  • 217 POSTS
do these vehicle even have a rotor? I think they are all electronic ignition.
why replace all o2 sensors? or is there only one.. not sure..
Oct 9, 2013 at 10:51 AM
JDL
  • 16,098 POSTS
I asked about engine litre size. The v8 shows coil near plug, no distributor. My info shows 4 oxygen sensors. I'd replace the front two for a start.
Oct 10, 2013 at 12:21 AM
UPMM019
  • 217 POSTS
shouldn't I just replace the one that is bad??
Oct 10, 2013 at 12:53 AM
JDL
  • 16,098 POSTS
With a tune-up, I'd replace the front two. It's your vehicle, do what ever you want. I doubt if replacing all four would hurt, anything.
If money is an issue, replace only one, that's up to you.
Oct 10, 2013 at 2:40 AM
UPMM019
  • 217 POSTS
For now I did just the one throwing the error code.
I pulled and replaced all spark plugs with OEM plugs and replaced the wires.
I also changed the air filter and the fuel filter.
After I did all of this I drove it for about 5-6 miles. Check Engine light still on but only solid not blinking.
I just drove it again and within the first few blocks the check engine light went off and stayed off for that drive.
I have an reader coming tomorrow so I will scan it again for codes.
The plugs were really really bad. some didn't even have tips and the gaps were huge.
Oct 10, 2013 at 1:11 PM
JDL
  • 16,098 POSTS
Sounds like your headed in the right direction. Keep us posted.
Oct 10, 2013 at 11:43 PM
UPMM019
  • 217 POSTS
Too good to be true... the suburban is now throwing the following codes:
Most recent read:
p 0171 system too lean bank 1
p0 300 random multiple cylinder misfire detected
prior read:
p 0131 02 sense or circuit low voltage bank 1 sensor 1
p 1153 manufacturer control
prior read:
What is the solution to these codes??
Oct 13, 2013 at 3:56 AM
JDL
  • 16,098 POSTS
Have you changed the 02 sensor? Also, check the 02 sensor wiring circuit.
Oct 13, 2013 at 5:19 AM
UPMM019
  • 217 POSTS
I changed bank 2
not sure about how to check the circuit.
Oct 13, 2013 at 5:40 AM
JDL
  • 16,098 POSTS
Just to add, the most common causes for po171 are, miscalibrated maf sensor--- exhaust or intake vacuum leaks---low fuel pressure/volume.
Oct 13, 2013 at 5:44 AM
UPMM019
  • 217 POSTS
How does one correct a miscalibrated MAF sensor?
Not sure how I find the exhaust/vacuum leak
Fuel pressure, not sure how that is checked either but I did change the fuel filter.
Oct 13, 2013 at 11:50 AM
JDL
  • 16,098 POSTS
With the engine idling, you could tap on the maf sensor, see if any effect on the idle. As far as exhaust leak, get under the vehicle and check it out.
As far as intake, you could spray some wd40 or something around the gasket areas, if the rpms take off, you found a leak.
As far as fuel pressure, use a gage and check fuel pressure. Some of the national brand autostores will loan out a fuel pressure gage. You may have to put up a deposit, but, you get it back when you bring the tool back.
Oct 14, 2013 at 12:44 AM
JDL
  • 16,098 POSTS
Just wanted to add, anytime you use a flammable spray of any king, you have to be careful about starting a fire or anything. Safety is your responsibility.
Oct 14, 2013 at 12:47 AM
UPMM019
  • 217 POSTS
where do I find the maf sensor? I am not familar with it?
is it something that can be easily replaced to solve these error codes?
Oct 14, 2013 at 3:45 AM
UPMM019
  • 217 POSTS
Ok. I am going to look at the Mass Air Flow now that I know what it is.... had to look it up.
I am going spray some cleaner in it... but not sure that will solve the issue.
Don't these just need to be replaced over time???
Can you visually look at the MAF and know it is bad or dirty, etc?
Oct 14, 2013 at 5:15 AM
JDL
  • 16,098 POSTS
My info says to not spray anything on it. The code doesn't tell you what to replace just that the system thinks there is problem on that circuit somewhere.
Forget the codes for a minute. Are there any driveability issues, still, after what you've done? If no driveability issues and no check engine lite, sounds like your good to go.
Oct 14, 2013 at 5:51 AM
UPMM019
  • 217 POSTS
it keeps throwing similar codes each time I drive it.
Oct 14, 2013 at 6:01 AM
UPMM019
  • 217 POSTS
do you think these issues could be tied to a dirty/faulty EGR value?
I've not looked at it but I did get these codes after cleaning the MAF.
P0171. Too lean bank 1
P0300 random\multiple cylinder misfire
P0404 exhaust gas recirculation control circuit range / performance
I don't think I have mentioned this but the exhaust spews out black carbon when you throttle it. I.e. all over side of garage wall.
Oct 14, 2013 at 7:12 AM
JDL
  • 16,098 POSTS
The egr should only be an issue at idle. I asked if there were driveability issues??? Is the check engine on??? As far as the vehicle running rich, have you checked fuel pressure and fuel pressure leak down?
At the moment, I don't care about the codes.
Oct 14, 2013 at 11:48 PM
UPMM019
  • 217 POSTS
If ignore the codes the only issues is at idle.
driving down the road it seems to drive just fine, other than the check engine light is one.
The only other thing is at idle it seems like it is rough and at time might die but never has.
Only other thing is the black crap that comes out the tail pipe
I don't know how to do the fuel pressure checks.
Oct 15, 2013 at 12:15 AM
JDL
  • 16,098 POSTS
The egr could have an effect at idle, so could a vacuum leak. You should have a Schrader valve on your fuel rail under the hood. The fuel pressure gage screws onto the Schrader valve.
Oct 15, 2013 at 12:54 AM
UPMM019
  • 217 POSTS
could the egr cause the prior codes?
Oct 15, 2013 at 12:58 AM
JDL
  • 16,098 POSTS
It's possible.
Oct 15, 2013 at 3:06 AM
