Codes P0300 and P0118, misfires, rough idle, car shaking and check engine light on
100,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
FR33SH
I’m having trouble with my car listed above. I get codes P0300 and P0118. i changed the temperature sensor, spark plugs, coils, cam and crank sensors and the runner valve. every code that came up has been tended to, but i am still getting misfire and rough idle. even my mechanic has been dumbfounded for the last 2 weeks.
Jun 6, 2020 at 3:52 AM
Good afternoon,
Did anyone check the fuel pressure? That is the most common issue for the 300 misfire code.
You can rent a tester at a parts store to verify.
Jun 6, 2020 at 4:45 AM
  • 55,721 POSTS
Also we should do a compression test as well.
Jun 6, 2020 at 5:43 AM
