Rough idle and stalling
270,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
JACOB GARLAND
When I cold start my engine, the idle is rough and uneven. It revs up and down to almost stalling (which it does sometimes). When I try to shift into reverse or drive while the engine is cold, it stalls. Also tries to stall when I stop at lights and when turning hard to the left. Replaced distributor cap and rotor, checked plugs, added STP fuel system cleaner. Still idling rough and stalling. Hearing a clunk when shifting. Possibly bad u-joint? Engine rattling like a diesel truck or pressure cooker in low gears, especially while climbing.
Jun 1, 2017 at 7:34 AM
JIS001
  • 3,412 POSTS
For the idle and stalling issue you should replace the idle air control valve first, also it sounds like you have a vacuum leak these guides will help us fix the problem.
https://www.2carpros.com/articles/stall-at-idle
and use this guide when the engine is cold only.
Let us know how it goes
Jun 4, 2017 at 1:39 PM
