Rough idle and stalls when in gear on at a stop light?
115,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
HIZZAY4LIFE
Good evening, sir, my car stalls at every stop and also idles very rough. please I need your help on what to do. thanks
Feb 1, 2023 at 3:22 AM
  • 110,248 POSTS
The most common issue that causes a rough idle and stalling is an engine vacuum leak. If you haven't already checked, that is where I would start.
Here is a link that explains how it's done:
If you find no leaks, the next thing is the idle air control valve (IAC). The IAC is responsible for maintaining the engine idle speed. It can become dirty and or damaged. That is what I would check next.
Here is a link that explains how to service one:
https://www.2carpros.com/articles/idle-air-control-valve-service
If you look below, I attached a link that covers in more detail what I discussed. Take a look through it and let me know if it helps.
https://www.2carpros.com/articles/stall-at-idle
Let me know what you find. Also, let me know if the check engine light is on and if you know of any codes stored.
Feb 1, 2023 at 11:30 AM
