Rough idle and shuts off at low RPMs?
1997 DODGE STRATUS
120,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CMANOVERFIELD
Car starts up no problem. Seems like when the engine gets good and warmed up it wants to idle rough at low RPMs and sometimes shuts off. It has absolutely no problems starting right back up after it shuts off. Also, not sure if it is a coincidence or not but seems like running the A/C in the car makes the problem worse? I have replaced the coil, plugs and wires, and the idle air control valve.
Jul 12, 2023 at 5:17 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Have you disconnected the battery recently? If you did, the fix is very simple.
Is there any other history or recent service that led up to this? Have you checked for diagnostic fault codes, or had them read. If any are set, what are the code numbers?
Jul 12, 2023 at 5:59 PM
CMANOVERFIELD
Yes, I disconnected the battery when I replaced the idle air control valve a couple weeks ago. I’ve had my cousin hook it up to an OBD, but I don’t remember what the codes were. I’ll have him hook it up to it again tomorrow if he can and I’ll write them down for you.
Jul 12, 2023 at 6:11 PM
CMANOVERFIELD
Yes I disconnected the battery when I replaced the idle air control valve a couple weeks ago. I’ve had my cousin hook it up to an obd but I don’t remember what the codes were. I’ll have him hook it up to it again tomorrow if he can and I’ll write them down for you
CMANOVERFIELD
Oh, sorry, no we didn’t disconnect the battery because it’s up in the fender.
Jul 12, 2023 at 6:21 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Rats. Regardless, there's one thing to do first, but this is mainly after the battery was disconnected or run dead. That is to drive it at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. That will meet the conditions needed to relearn "minimum throttle". That is the only thing that doesn't get relearned automatically, without you noticing.
If that doesn't help, we need to look at the "idle steps" on a scanner under the "live data" menu. That pertains to the automatic idle speed motor, (idle air control valve). The Engine Computer can set that to any of 256 "steps" to adjust idle speed. For a properly running engine, expect it to be close to step 32. If it is significantly higher than that, the computer is trying to increase engine speed, but without success. A good suspect for that is an air passage around the throttle blade that's blocked with carbon. Haven't seen that much since the '90s thanks to better additives in today's gas.
If it's at a much lower step number, the computer is lowering idle speed in response to something. We have to identify that something.
If the idle steps are at "0", minimum throttle hasn't been relearned.
Chrysler made reading the diagnostic fault codes much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds, without cranking the engine. Leave it in "run", then watch the code numbers appear in the odometer display. You can go here:
https://www.2carpros.com/trouble_codes/obd2/p0400
to see the definitions, or I can interpret them for you. Let me know what you find with these things, then we'll figure out where to go next.
Jul 12, 2023 at 6:55 PM
