Code P0171 rough idle and idle surging
169,300 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JAIHIER JORDON
  • 15 POSTS
I’m having a rough idle and surging from what I guess is a P0171 error code meaning that bank one is running lean, I’ve replaced a number of parts and nothing is working.
Jun 3, 2020 at 1:19 PM
  • 110,248 POSTS
What parts have already been replaced? Also, a lean mixture can be the result of several different things. However, the most common are low fuel pressure or an engine vacuum leak. I have even seen an exhaust manifold (pre catalytic converter) leak cause it. Have you noticed any exhaust issues? It could actually sound like a ticking.
If not, the next thing I suggest is to check for engine vacuum leaks and fuel pressure. Here are two links to help with that process:
If you have already tried this, let me know. Also, let me know if you have a live data scan tool. There are several other things that can be checked such as a faulty engine coolant temperature sensor, air intake temp sensor, mass air flow sensor and so on.
The attached pic indicates the manufacturer's specs for fuel pressure.
Jun 3, 2020 at 1:34 PM
JAIHIER JORDON
  • 15 POSTS
I have replaced the PCV valve, spark plugs, ignition coils, fuel injectors. cleaned the MAP and MAF sensors and the throttle plate. There has always has been a ticking noise that has went on when you turn the key into the on position, and I do have a live data scan tool. And I haven’t tried getting a fuel pressure reading.
Jun 3, 2020 at 9:10 PM
JAIHIER JORDON
  • 15 POSTS
Tried to get a fuel pressure reading, but everyone was booked up through the week and I have no idea what else to do.
Jun 4, 2020 at 12:53 AM
  • 110,248 POSTS
The P0302 indicates a misfire on cylinder 2. That is likely what you feel. Since there is a lean mixture, that could be the cause. Can you do me a favor? Take the live data scanner and check short term fuel trims and the oxygen sensor readings. Let me know what you find. Also, does the ticking sound go away after the engine warms up? Have you confirmed there are no vacuum leaks?
Jun 4, 2020 at 1:47 PM
JAIHIER JORDON
  • 15 POSTS
Alright I will. The ticking sound is then you turn the key into the on position and I have confirmed that there are no vacuum leaks.
Jun 5, 2020 at 1:05 AM
  • 110,248 POSTS
Let me know what you find. Also, I assume the ticking is with the engine off, so that isn't an exhaust leak. I have a feeling we have a fuel pressure issue.
Jun 5, 2020 at 1:46 AM
JAIHIER JORDON
  • 15 POSTS
This is when I ran live data, all of the fuel trims are in there. The long term fuel trim doesn’t budge, but the short term jumps a lot.
Jun 5, 2020 at 8:04 AM
  • 110,248 POSTS
The O2 sensor is reacting properly. The STFT1 is really high, indicating the computer is trying to add fuel. STFT2 is right on. How does your scan tool differentiate or what does it differentiate between 1 and 2?
Jun 5, 2020 at 3:00 PM
JAIHIER JORDON
  • 15 POSTS
I don’t really know, that question sort of just stumped me, I’m sorry. But you say it’s trying to add fuel so that would mean there’s too much air?
Jun 6, 2020 at 3:08 AM
  • 110,248 POSTS
Yes. In a perfect world, the fuel trims would be at 0. It's normal for them to fluctuate a bit. The one that is at 15 indicates it's trying to compensate by adding fuel to the mixture. If that number was negative (for example -15) that would indicate it is trying to limit the fuel. So the idea that it is +15 tells me it is trying to add fuel because there is too much air resulting from a leak or low fuel pressure.
I hope that makes sense. Please feel free to ask any questions. If I can answer them, I will.
Jun 6, 2020 at 4:39 PM
JAIHIER JORDON
  • 15 POSTS
I understand, so what would it turn out to be if there was, for example, a line that had a hole and was pulling in air?
Jun 6, 2020 at 10:08 PM
  • 110,248 POSTS
It would be in the upper + (positive) range. Basically, where it is now. Under normal conditions, at an idle I would expect to see the STFT's to be changing between negative and positive 2-5%. It's staying near +15%.
Jun 7, 2020 at 1:20 PM
JAIHIER JORDON
  • 15 POSTS
Thank you Joe, and I got one more question, what would I need to get to test if there is a leak in the air system and in the fuel system?
Jun 7, 2020 at 11:02 PM
  • 110,248 POSTS
Basically for a fuel pressure test, you need a fuel pressure gauge. Here is a link that shows how that is done. Most auto parts stores will lend/rent the gauge to you.
Here is a link that explains how to locate a vacuum leak:
Jun 8, 2020 at 12:29 AM
JAIHIER JORDON
  • 15 POSTS
I will, thank you Joe.
Jun 8, 2020 at 2:25 AM
JAIHIER JORDON
  • 15 POSTS
I went over every hose that leads to the intake or is attached to it, and it sucked in none of the carburetor cleaner. And I just did a live data scan, when I brung the rpms up both STFTs went into the positives, I don’t know if that makes it more confusing or a lot easier to recognize
Jun 8, 2020 at 8:36 AM
  • 110,248 POSTS
If you are referring to when you first press the throttle to rev the engine, that is expected. Any luck checking fuel pressure?
Jun 8, 2020 at 1:05 PM
JAIHIER JORDON
  • 15 POSTS
I haven’t been able to check it yet. I’m going to go get a kit tomorrow for it and yeah, I’ve just been pressed on figuring everything out before I go into surgery.
Jun 8, 2020 at 2:18 PM
  • 110,248 POSTS
Let me know what you find. Also, anytime I hear surgery, it isn't good. I hope you are well and everything goes smoothly for you.
Jun 9, 2020 at 1:45 PM
JAIHIER JORDON
  • 15 POSTS
Thank you, and when I tried doing the fuel pressure, I kept having leaks, and when I primed the pump I took the line off and it didn’t come out like it had pressure in it.
Jun 9, 2020 at 10:52 PM
  • 110,248 POSTS
There was no pressure from the fuel pump?
Jun 10, 2020 at 1:23 AM
JAIHIER JORDON
  • 15 POSTS
So, I took it to a shop where they looked over everything, and it turns out my MAF is shot.
Jun 13, 2020 at 1:07 AM
  • 110,248 POSTS
I just read over everything we talked about. In my mind, the MAF was already replaced but I saw you cleaned it. I am so, so, so sorry I missed that. Ugh!!! Is it running properly now?
Jun 13, 2020 at 12:15 PM
JAIHIER JORDON
  • 15 POSTS
It’s alright, I missed it too, I thought it just needed a good clean but when I looked into a bit more, it’s barometric readings were so off and then I took it to a shop where I know the mechanic who did it, and they ran a test on all of the sensors considering the air and fuel, and the MAF was bad just from that, they even took it out and cleaned it.
Jun 14, 2020 at 12:30 AM
  • 110,248 POSTS
Well, I'm just glad it's running properly for you. Please feel free to come back in the future if you have questions.
Jun 14, 2020 at 9:54 AM
JAIHIER JORDON
  • 15 POSTS
I definitely will, and thank you so much for helping me and going through everything with me, you’ve been a massive help, and I appreciate it.
Jun 15, 2020 at 3:58 AM
  • 110,248 POSTS
You are very welcome. I don't want you to have more problems, but if you do, I hope to see you again in the future. Take good care of yourself.
Jun 15, 2020 at 12:03 PM
