Rough idle
231,000 MILES • V8 • 2WD • AUTOMATIC
JBAKER72
  • 7 POSTS
Had A/C compressor taken off and by-pass pulley put on. Now it idles slightly rough and shutters when it hits 35 mph, but smooths back out at 40.
Oct 16, 2018 at 11:48 AM
  • 110,248 POSTS
I am not sure how the bypass would be causing this problem. Is the check engine light on?
Since you just had this work done, my first suspect is a vacuum leak that was caused while the work was being done. First, if the check engine light is on, have the computer scanned to identify diagnostic trouble codes. Here is a video showing how that is done:
https://youtu.be/YV3TRZwer8k
Next, check to determine if there is an engine vacuum leak. Here is a link that shows how to check:
Try these things first and let me know what you find.
Oct 17, 2018 at 9:57 AM
