My truck sounds like it has a miss and it idles rough as soon as it is started
Sunday, August 29th, 2010 AT 3:43 PM
MECHANIC
Has the check engine light come on? When was the last tune up? What size V8 do you have? And finally have you checked fuel pressure and for vacuum leaks?
SPONSORED LINKS
Monday, August 30th, 2010 AT 8:09 PM
FABIAN67
MEMBER
Yes tune up was just done and no check engine light came on and fuel pump pressure is down by 10
Monday, August 30th, 2010 AT 8:21 PM
MECHANIC
The fuel pressure could be causing the problem. Have you checked for vacuum leaks?
