Code P1684, rough idle
255,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
CUMLAUF0213
I have replaced the MAP sensor and coil pack, spark plugs and wires. And it is still running rough. I also did the turn the key 3 times and got the code P1684.
Jan 20, 2021 at 2:11 AM
SEVAG P
  • 405 POSTS
hello,
I don't think engine rough running is related to fault code p1684, this fault is related to transmission, battery positive disconnected or disconnected from the transmission control unit. check the attachment below for the diagnostic procedure for fault code p1684.
use scan tool read the fault codes to narrow down our problem, check our guide how to read faults.
https://www.2carpros.com/articles/engine-hesitates
Check for any vacuum leaks that can cause also engine rough running.
Jan 20, 2021 at 3:20 AM
