Rough idle
1,333 MILES • 4.0L • V6 • 4WD • AUTOMATIC
JEPWO6
  • 15 POSTS
How to test the coil packs?
Oct 22, 2019 at 11:54 PM
You have what is called coil on plug ignition coils so there are 6 of them. Due to this being the case, you can test each coil but it is better if we use a scan tool to find out it there are any misfires.
Rough idle can be caused by many things so if there is no check engine light, let's check for vacuum leaks first.
I attached the various tests for the coil if you locate a signal or multiple misfires.
Oct 23, 2019 at 10:34 AM
