Engine has a rough idle
14,200 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
PEPEDECOTEAU
i change the plugs, and coil pack and my car still rough idle. Can a bad fuel pump hose inside d gas tank cause this?
Jun 18, 2022 at 2:18 AM
SQM
  • 6,383 POSTS
There are a number of reasons why an engine can have rough idle or misfire.
It could be due to ignition issue, fuel injectors, low fuel pressure, vacuum leak etc.
Take a look at this guide. It covers the usual issues.
Are you getting any error codes? Is the check engine light on?
If the engine light is illuminated, scanning, and retrieving the code(s) can help with the diagnostics.
Let me know of any questions.
Jun 18, 2022 at 8:43 AM
