Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Galant
Engine
Symptoms
Idle Rough
Rough idle
2001 MITSUBISHI GALANT
189,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
CANDACE LEWIS BREWER
MEMBER
My car will start, but irregular idle then does. I have had the MAF Sensor, all sensors changed basically. No vacuum leak. Any new ideas?
Sep 1, 2016 at 3:19 PM
SATURNTECH9
Experienced Mechanic
Have you checked for codes in the computer yet?
Sep 1, 2016 at 3:42 PM
MEMBER
Yes, also used throttle cleaner on it. Im about ready to sell it, this would be a mechanics dream.
Sep 3, 2016 at 8:26 AM
I would start with a compression test to see if you have a low cylinder. You could have a intake valve leaking.
Here is a guide that will show you how to test it.
Best, Ken
Sep 5, 2016 at 2:49 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
