Rough idle
200,000 MILES • 6 CYL • AWD • AUTOMATIC
BAMBAM187
Well, I changed the plugs now it has a rough idle. I do not know what to do. I have tried to reset the system it is not working. I have checked all the plugs make sure everything was connected right, it still runs rough.
Mar 11, 2017 at 11:02 PM
HMAC300
  • 48,601 POSTS
sometimes new plugs do that. drive it for a few miles see if it straightens out. then check your plug wires and for a vacuum leak.
Mar 12, 2017 at 12:35 AM
BAMBAM187
I have done that drove it sixty miles no change.
Mar 12, 2017 at 1:32 AM
HMAC300
  • 48,601 POSTS
okay, check for a vacuum leak and check fuel pressure with a gauge auto parts rent that. should be 60-66 psi with lower number minimum also should hold with in 10 psi for five minutes at least.
Mar 12, 2017 at 1:47 AM
