Just bought this truck and at low rpm's it idles rough, also while driving at low rpm the truck jerks a bit. If you keep the rpm's up it runs out fine, no jerks or roughness only at idle or low rpm's. Replaced MAF sensor, IAC sensor, spark plugs and wires. Any ideas? Also checked for vacuum leaks none that I found. Thanks
Sep 13, 2017 at 12:13 PM
