Rough idle
126,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
ROBHAWK
Through scanner intake air temperature was showing 78 degrees. Ambient temperature 55 degrees. Is this a problem and if so where is sensor located? 3.0si
Feb 22, 2019 at 8:00 PM
SCGRANTURISMO
  • 4,897 POSTS
I don't think that would effect your idle that much. I have included the Intake Air Temperature (IAT) sensor location in the diagrams down below as well as a troubleshooting guide from the manufacturer for your vehicles rough idle. Please go through this guide and get to us with you find out.
Thanks,
Alex
2CarPros
Feb 22, 2019 at 10:43 PM
BMDOUBLE
  • 1,139 POSTS
Common faults on these for rough idle is the PCV system (positive crankcase ventilation system). Remove your oil cap and see if there is a strong suction. If there is, you will have to replace the valve cover (plastic). Or if it’s a metal valve cover you will have to remove the intake and replace the CCV valve assembly, same thing different name.
Feb 23, 2019 at 12:35 AM
ROBHAWK
After replacing a coil on cylinder number two (misfire) and left and right DISA valves (one broken flap and one with damaged gasket and frozen in open position) the problem has been corrected. Decided to replace all three coils on 1, 2 and 3 cylinders to rule a random misfire on bank 1.Ten mile test drive and idle was smooth afterwards with no CEL.
Feb 23, 2019 at 10:27 PM
  • 55,721 POSTS
BMDOUBLE is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Feb 26, 2019 at 3:33 AM
