rough idle
108,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KARCH1963
Hi Guys,
I recently did a tune up on the car listed above. i changed the spark plugs gap 32, distributor cap, wires and rotor. i changed PCV as well.
Before this tune up the car had a rough start but now it starts right away, but has a rough idle.
can you please help?
Mar 9, 2017 at 11:06 PM
  • 55,721 POSTS
I would recheck the spark plugs it sound like one might be cracked, if the plugs are okay I would do a compression test. here is a guide to see if you have a low cylinder.
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 10, 2017 at 4:02 AM
