Rough idle
CHRIS SENSING
  • 2001 PONTIAC GRAND AM
  • 2.4L
  • 4 CYL
  • 118,400 MILES
So I have replaced the TPS sensor IAC thinking it was fuel injectors, but I read your post about putting washers in. Did you put them between the frame and mount?
Monday, January 14th, 2019 AT 3:46 AM
  • 52,797 POSTS
Good morning,
Have you replaced the spark plugs? Rough running is most commonly caused by worn ignition parts.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Compression test would be next to be sure there is no internal engine damage.
Check for any vacuum leaks, broken or disconnected hoses as well.
Is the check engine light on?
Monday, January 14th, 2019 AT 3:55 AM
