Rough idle?
72,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ROBERT WALBROEHL
  • 122 POSTS
When idling car is not as smooth as it used to be. Cleaned throttle body with spray, changed air cleaner.
Nov 3, 2022 at 1:11 AM
  • 55,721 POSTS
This can be a vacuum leak which I would test when the engine is cold only. here is a guide to help you also have you installed new spark plugs and coils. That is a problem with these cars, here is how to change them out as well:
Spark Plug Type:
DENSO .................... SK20R11
NGK .................... IFR6A11
Spark Plug Gap New - mm (in.): .................... 1.0 - 1.3 (0.039 - 0.051)
Torque: .................... 18 N.m (178 kgf.cm, 13 ft.lb)
This guide will help walk you through the replacement:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Please go over these guides and report back.
Nov 3, 2022 at 6:10 AM
ROBERT WALBROEHL
  • 122 POSTS
I believe my 2006 Toyota corolla takes sk16r11 and not sk20r11 that you suggest. Could you double check that? Thanks, Robert
Nov 3, 2022 at 10:04 AM
  • 55,721 POSTS
Hi Robert,
I show 1.8 liter engines for this car can you please confirm the engine size?
Nov 5, 2022 at 4:41 AM
ROBERT WALBROEHL
  • 122 POSTS
Yes, 1.8 liter.
Nov 6, 2022 at 4:15 AM
  • 55,721 POSTS
There are two different 1.8 liter engines here is the spark plugs for this option, L4-1.8L (1ZZ-FE)
Spark Plug Type:
DENSO .................... SK16R11
NGK .................... IFR5A11
Torque: .................... 25 N.m (255 kgf.cm, 18 ft.lb)
Nov 7, 2022 at 3:23 AM
