My brake pedal is Rough I changed the Booster yesterday brand new the master cylinder is good I think I bled all brakes any ideas ?
Jan 13, 2016 at 6:09 AM
✓Experienced Mechanic
can you explain rough???? does it vibrate???
Jan 13, 2016 at 6:46 AM
WESKOAST
MEMBER
Hey Roy it doesn't vibrate unless I force it.
Jan 13, 2016 at 6:50 AM
force it???please explain
Jan 13, 2016 at 6:51 AM
WESKOAST
MEMBER
When I push brake pedal it's rough
If I force the brake pedal down it's rough still but does vibrate a bit as I keep pressing on the brake I've changed a brand new booster but it's still rough when I brake.
Jan 13, 2016 at 6:55 AM
it sounds like you may have out of round rotors that may effect the brake pedal.
Jan 13, 2016 at 7:02 AM
WESKOAST
MEMBER
I'm definitely going to check that out tomorrow if I need any more assistance can I message you again tomorrow?
Jan 13, 2016 at 7:06 AM
of course
Jan 13, 2016 at 7:07 AM
WESKOAST
MEMBER
Hey Roy what's up so I double checked the rotors everything looks fine do you think maybe the Master Cylinder is not good ?
