Rotor size
15,000 MILES • 1.5L • 3 CYL • AUTOMATIC
CMASTIN2
Hi, so I was wondering if the rotor has to be the size that it's called for? because i found a rotor that is just one inch bigger in diameter but the screws match up and it fits just fine but will it be a problem is the rotor is just an inch too big? like can i drive with a little bit bigger rotor or will i not be able to?
also the depths are the same. so basically the only difference with this rotor is it's one inch bigger in diameter than the others and what my car calls for.
Jan 19, 2016 at 12:39 AM
WRENCHTECH
  • 20,758 POSTS
Most definitely that is a problem. You have to have the EXACT rotor that belongs to that car, not just one that measures the same. there are other factors that matter too.
You wouldn't even be able to install that one.
Jan 19, 2016 at 12:58 AM
CMASTIN2
oh okay thank you!
Jan 19, 2016 at 1:08 AM
