Rotor is not spinning
1,800,000 MILES • 6 CYL
MICHELLE BANES
Van turns over but will not start. I was driving and all a sudden it quit running. will not start now.
Jun 20, 2017 at 10:06 AM
CARADIODOC
  • 34,414 POSTS
I am going to assume you have the 3.0L engine. If that is correct, the best suspect is the timing belt broke. This is an interference engine, so there will likely be bent valves too.
Jun 20, 2017 at 12:45 PM
