Rotor drum wear
166,000 MILES
BERN50
Are these numbers good 0.512 in and 0.478? Where I should I not have to change the rotors?
Nov 20, 2018 at 10:15 PM
JONNYB1963
  • 263 POSTS
Thank you for visiting 2CarPros!
According to the manufacturer specifications the minimum rotor thickness for the front brake rotors is 1.040" and for the rear it is .409" See the chart attached.
Generally you replace rotors for two reasons. One is that they are worn out below the minimum thickness. Two is if they are warped and cause your brake pedal to pulsate meaning that they are warped (they have "runout"). If both thickness and runout are good, then there is no need to replace them.
Regards,
Jon
Mar 15, 2021 at 5:27 AM
