Rotational squeaking at 15 MPH?
176,400 MILES • 4.8L • V8 • 2WD • AUTOMATIC
ELDELATROCAGRIS04
  • 8 POSTS
I’m hearing a rotational squeak that does it in synchronization with the wheels spinning, it starts at 15mph and is more audible when I initially start driving the truck in the morning or after my 8 hour shift at work and seems to quiet down when I drive for a while I can barely hear it, it would be audible when I pass by a car or wall where the sound echos. It seems to be coming from the rear, I have replaced both front wheel hub bearings and in the rear I have replaced both u joints 2 years ago, had them checked by a mechanic recently and there is no play or clunking noise, changed the rear differential oil 3 years ago and there was no metal shavings at the time it got done so now I’m stuck between rear wheel bearings or worst case rear differential getting ready to go out? Sound does not change when I brake so I don’t think it’s brake related. I attached 2 videos of the noise hoping someone can help me out.Thanks.
Jul 17, 2024 at 11:32 AM
  • 110,248 POSTS
Have you pulled the rear brake rotors to inspect the parking brake shoes? Something could be happening with a retainer. Also, check to make sure the rear backing plate/dust shield isn't rusted and touching the rotor.
Do this and let me know if you find. If you have already done this, let me know.
Jul 17, 2024 at 1:17 PM
ELDELATROCAGRIS04
  • 8 POSTS
Both rear Parking brake shoes were replaced along with the included hardware recently thinking that was the noise, still no change, I checked the backing plates and they are not touching, had a mechanic check the u joints and they are tight no play and greased, he says rear wheel bearings are not bad but could be wrong or worst case differential carrier bearing? For some reason the videos did not attach on my original post so hopefully it shows on this reply and as you can see it starts at 15 MPH and gets faster the faster I go.
Jul 18, 2024 at 10:31 AM
  • 110,248 POSTS
I have a question. In the second video, I heard a squeak once. I also heard clicking. Is the clicking from the road or is that what you are referring to?
Also, the squeak I heard didn't sound rotational. It sounded similar to a bushing that is part of the suspension.
Also, a bearing, in most cases, will make a growling noise or a hum that changes with speed and if you are making turns. Is that a possibility as to what you hear?
Jul 18, 2024 at 12:46 PM
ELDELATROCAGRIS04
  • 8 POSTS
Hi Joe, that clicking noise was my keys hitting the column plastic, so I’m maybe using the wrong term on the squeak it’s more like a squeal type of noise that does it in synchronization of the truck moving it starts at 15 mph and gets faster the faster I go, at higher speeds over 50 I don’t hear it because of road and wind noise. I checked my suspension by bouncing it up and down front and back and no squeaks, so the noise sounds like something that moves as the truck moves I’m maybe thinking rear wheels bearings but the mechanic checked it off he may be wrong or worst case differential but the truck handles perfectly and tires show no signs of uneven wear or no howling noise.
Jul 20, 2024 at 11:06 AM
  • 110,248 POSTS
Okay. If you are driving 35mph, is there anything you can do to change the pitch or sound you are hearing? For example, if you make a turn, does it get louder or stop?
Jul 20, 2024 at 3:31 PM
ELDELATROCAGRIS04
  • 8 POSTS
Hi, so I noticed that when the sound quiets down, once I drive through bumpy roads or when doing a turn with potholes it sounds like a chirping and once I start going 15 MPH and over the noise starts again and when passing by cars or walls the noise echos to me.
Jul 21, 2024 at 4:44 AM
  • 110,248 POSTS
Have you reconfirmed that there isn't a bent brake wear indicator that is touching the brake rotor? I'm not saying it isn't a bearing, but I would be looking at things that are less expensive first. LOL
If you are sure there is nothing touching the rotor (wear indicator, stone, or dust shield), chances are, it is a bearing. I am basing that on the idea that it is a rotational noise.
Let me know your thoughts.
Jul 21, 2024 at 11:52 AM
ELDELATROCAGRIS04
  • 8 POSTS
Hi, just checked the rotors and there is no debris in between or dust shields aren’t touching them and pads and rotors were replaced 3 years ago and are still in good condition, noise doesn’t change when braking it’s consistent as the wheels are moving and when I slow down to less than 15 MPH when coming to a stop the noise stops. So now I’m thinking rear wheel axle bearings too because usually a bad differential would make a whine/humming noise or sound like a dirt bike when accelerating faster based on a couple YouTube videos of bad differential?
Jul 21, 2024 at 4:25 PM
  • 110,248 POSTS
That makes sense. If nothing is touching, chances are it is a bearing. Can you tell what side the noise comes from?
Jul 22, 2024 at 1:18 PM
ELDELATROCAGRIS04
  • 8 POSTS
Hi Joe, I’m back again with the same issue the rotational noise, just went on a 4 hour round trip and now I’m hearing the same squeaking noise that starts at 5mph but when I go a little faster I hear this chirping. I jacked the truck up, put it in neutral and spun the wheel and it’s making these scraping a grinding noises, any idea what it can be? Thank you.
Aug 14, 2024 at 8:14 AM
  • 110,248 POSTS
I hear something that sounds like something is vibrating. Is that what you are referring to? I hear it best in the first video.
Aug 14, 2024 at 2:12 PM
ELDELATROCAGRIS04
  • 8 POSTS
Hi, yes the grinding noise and the intermittent scraping maybe could be a warped rotor but the grinding is my concern.
Aug 14, 2024 at 2:14 PM
  • 110,248 POSTS
I couldn't notice any grinding. Does the sound change when you apply the brakes?
Aug 15, 2024 at 11:54 AM
ELDELATROCAGRIS04
  • 8 POSTS
Hi, no sound doesn’t change when braking, it’s constant as the wheels are spinning.
Aug 15, 2024 at 1:22 PM
  • 110,248 POSTS
The only thing I can think of is if there is a bearing issue again or something is rubbing.
Aug 16, 2024 at 1:37 PM
