I'd like to verify which way running rotation is
149,000 MILES • 2.0L • 4 CYL • 2WD
JCLEMO
  • 161 POSTS
While I'm asking questions about the Kia and timing issues I'd like to verify which way running rotation is. Standing facing the engine do you rotate the crankshaft clockwise or counter clockwise to align the two cam sprockets to the back plate notches?? I have been turning clockwise. Thanks. JC
Jun 28, 2019 at 11:01 AM
SQM
  • 6,383 POSTS
You are turning it correctly. Clockwise is the directing they need to be turned.
https://www.2carpros.com/articles/how-camshaft-variable-valve-timing-works
I have attached the replacement procedure for the cam below.
Oct 15, 2021 at 6:31 AM
