Rotor
90,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
ZIGGIEDOWN
Hexadecimal screw holding rotor is stripped. how can I remove this screw?
Aug 10, 2017 at 3:08 AM
STEVE W.
  • 15,418 POSTS
The 1984 has through bolts that hold the rotor on correct?
I know some went through as a bolt/nut while others screwed into a threaded hole in the hub.
If these are the through bolted ones you can use a chisel to break the nut off the bolt. Or you can use a torch and heat the nut to red hot and it should come off.
Another option is to buy a twelve point socket that you can drive onto the nut/bolt head after heating it and use that to remove it.
Aug 10, 2017 at 3:23 AM
