Roof module connector wiring diagram needed
5,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KBENN165
I'm looking for roof module wiring harness diagram. Can anyone recommend a website?
Nov 23, 2021 at 6:29 AM
STEVE W.
  • 15,389 POSTS
What is the issue you are having? The attached is the wiring for the sunroof, is that the module you are looking for or something else?
Nov 23, 2021 at 7:40 AM
KBENN165
I need the roof console part #84608538 which has 2 16 pin connectors need to know pin location, wire color code, so I can solder new connector ends. Truck was damaged. A wiring diagram should work. thanks
Nov 26, 2021 at 10:01 AM
STEVE W.
  • 15,389 POSTS
Okay, try these there are what they have plus the pin outs for both connectors. Watch the colors. Those should help.
Nov 26, 2021 at 11:06 AM
