Runs rough until it gets to 3,000 RPMS
240,000 MILES • TURBO • 2WD • MANUAL
929CHRIS
  • 7 POSTS
Once the turbo kicks in it runs great other than it sounds like it is missing on all cylinders. i change the fuel pump, fuel pressure regulator, and i changed the distributor.
Dec 15, 2021 at 4:01 AM
  • 110,251 POSTS
A misfire can be caused by several things. Have you checked for engine vacuum leaks? Has anyone changed the air intake tube?
Do me a favor. Let's start by checking for diagnostic trouble codes. This vehicle has an OBD1 system. You can retrieve codes without a scan tool. Take a look through this link and let me know if you find codes:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Also, let me know if the engine has 240,000 miles. If possible, record how it is running and upload it for me to hear.
I will wait for your reply.
Dec 15, 2021 at 11:15 AM
929CHRIS
  • 7 POSTS
How do i upload an audio clip?
Dec 18, 2021 at 2:29 PM
  • 110,251 POSTS
At the bottom of where you are typing, click on the "Add Image or Video."
Let me know if you find it.
Dec 18, 2021 at 2:41 PM
929CHRIS
  • 7 POSTS
It has codes 15,16,17.
Dec 19, 2021 at 3:25 AM (Merged)
