I am fairly sure that they are an SU type in line electric pump, i know the earlier pumps are under the car on the R/H/S have look there.
Mark (mhpautos)
Jan 29, 2010 at 4:06 PM
NHEGNA
MEMBER
1 POST
The 82 Spur Fuel pump is not- in the tank
it is an inline electric pump located adjacent to the tank ( right rear )
please note the well known problem with the fuel pump fuse ( # 13 ) and its normal aftermarket replacement ( a breaker ) check the fuse board located in the drop down panel under the glove box - ( press the button on the far right panel )
