Roller rockers and pushrods
130,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
JACOB HENDRIX
  • 8 POSTS
Cylinder one will not hold compression so I started taking it apart and I am down to the head and the valve cover is off. I do not know if the roller rockers have to come off before the head and if so do they have to be in a certain position? Also how do you adjust them when reinstalling?
Apr 23, 2016 at 3:57 AM
HMAC300
  • 48,601 POSTS
togue to 22 ft lbs. when reinstalling after snugging all of them down.
Apr 23, 2016 at 9:45 AM
JACOB HENDRIX
  • 8 POSTS
So it does not have to be at top-dead-center when removing?
Apr 23, 2016 at 10:35 AM
HMAC300
  • 48,601 POSTS
No, not if you are just removing the heads.
Apr 24, 2016 at 1:10 AM
JACOB HENDRIX
  • 8 POSTS
Do you have to use feeler gauges to set valve lash?
Apr 24, 2016 at 5:38 PM
HMAC300
  • 48,601 POSTS
No, you just torque the bolts down.
Apr 24, 2016 at 11:45 PM
JACOB HENDRIX
  • 8 POSTS
What are the head bolts torque specs and sequences
Apr 26, 2016 at 6:42 AM
HMAC300
  • 48,601 POSTS
see pics also use Loctite pipe sealant on threads of head bolts NOT TEFLON TAPE
Apr 26, 2016 at 8:28 AM
