Rear wheel stud removal?
458,000 MILES • 3.2L • V6 • 2WD • MANUAL
MARKIEMAC88
Hi i have the vehicle listed above Ute 2wd 6 stud 3.2 v6. I have broken a wheel stud on the driver's right side rear and was wanting to know how to remove it and replace it with a new one. Thanks Mark.
Jan 30, 2023 at 9:53 AM
BORIS K
  • 836 POSTS
To replace rear wheel studs on your vehicle is not too difficult.
You will need to safely raise the vehicle at the rear, remove the wheel.
Next release the handbrake and remove the brake drum so that you can access the wheel hub.
Take a hammer and knock the broken wheel stud out.
Next insert the new stud, space the thread and use the wheel nut to pull in the new stud.
Reinstall the brake drum and wheel.
A good video:
https://youtu.be/vdZGl-iU-ms
and
https://youtu.be/QDNZDR8mBhk
Hope this helps.
Cheers, Boris
Jan 30, 2023 at 8:05 PM
