Rod knock sensor replacement instructions needed
115,000 MILES • 0.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
FRVNK
  • 20 POSTS
Hello, I got a code that my rod knock sensor is bad and needs replacement. I was hoping you could give me a diagram and instructions on how to fix the problem. I’m not to sure where the rod knock sensor is located.
May 29, 2020 at 1:45 AM
  • 110,248 POSTS
There are several different knock sensors on this engine. Do you have the specific code from when it was scanned? I don't want to tell you the wrong one and without the code, I don't know which is needed.
If you look at the attached pic, you'll see what I am referring to.
May 29, 2020 at 2:05 AM
FRVNK
  • 20 POSTS
Yes, sorry. codes are p0326 and p0172. theses both came out when they scanned. thank you.
May 29, 2020 at 2:24 AM
  • 110,248 POSTS
Okay, that indicates cylinder 1 (p0326) I attached two pics below. The first is the description of the code identified by Mercedes as P032600. Pic 2 shows the sensor location.
Let me know if this helps.
May 29, 2020 at 2:41 AM
FRVNK
  • 20 POSTS
Thank you so much. what about the other code what was that about?
May 29, 2020 at 2:53 AM
  • 110,248 POSTS
The other code deals with the computer controlling the air fuel mixture. I suspect once the knock sensor is replaced, it should go away.
Let me know if it doesn't.
May 29, 2020 at 11:07 AM
