Diagram needed for the steering column?
180,000 MILES • AUTOMATIC
MONICA BRADLEY
There is a rod in steering column that pushes down on the switch on a button that ignites the ignition, where is it connected to on the front part of it by the turn blinkers? the tilt lever something on mine is broke off and I can't figure it out and I keep looking up diagrams to try to see the picture of the inside of the steering column right there with a tilt switch and I can't find one.
Mar 18, 2023 at 2:33 AM
  • 110,248 POSTS
I'm not sure if you are looking for. If it is the rod that goes to the ignition switch itself, the opposite end goes to the ignition lock cylinder which moves when you turn the key.
I attached an exploded view of the steering column below. (Pic 1) The remaining pics are the legend for each part.
Let me know if you see what you are looking for or if you have other questions.
Mar 18, 2023 at 6:06 AM
