Rocker arm loose
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
TIM MOORE
Had a rattle in top end, took valve cover off found a real loose rocker arm. should i torque it back down or what?
Dec 8, 2017 at 11:36 AM
  • 55,691 POSTS
There are a few scenarios that can cause a loose rocker arm. First is the obvious the rocker just came loose. The next problem would involve a collapsed lifter. the final problem which i hope is not happening is the valve seat in the cylinder head is working its way out of the casting.
Can you please take a picture to show me the effected rocker and valve spring? Try to get the other cylinders around it as well. I am looking for a height difference between the others.
https://www.2carpros.com/articles/how-a-cylinder-head-works
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Dec 10, 2017 at 6:42 AM
