Rack and pinon
1,000,000 MILES
GVFZ
  • 27 POSTS
The rack and pinon is failing and I need to removed it, can you help me by sending me the directions on how to remove it please?
Apr 17, 2016 at 4:02 AM
  • 55,628 POSTS
Hey Gvfz,
First jack your car up safely by following this guide
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Then undo the bolt to the steering column, followed by the tie rod ends follow the guide below:
https://www.2carpros.com/articles/tie-rod-end-replacement
Next, would be the power steering lines be sure to have an oil drain pan ready because fluid will leak out at this point.
Next: Remove the main rack mounting bolts.
Once the rack is out match it too the new unit, and reverse these instructions to reassemble , please let me know if you have any further question or problems you would like help with.
Best, Ken
Apr 18, 2016 at 4:24 AM
