Engine sputtering, backfires and check engine light is blinking
156,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
MYRICKS97
I have a truck that started sputtering and actually backfires in the front of the vehicle. The check engine light starts blinking when I push it to get up a hill. It’s been two days and haven’t driven it unless I had to, but any insight would be appreciated!
Mar 20, 2021 at 3:12 AM
Good afternoon,
I would start by checking the compression. Backfire and low power usually has something to do with one cylinder with low compression.
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/engine-backfires-while-running
You should have 140-160 pounds in each cylinder.
Mar 20, 2021 at 3:50 AM
