Roaring front could it be a bad hub?
2000 FORD MUSTANG
231,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRIS KINARD
  • 94 POSTS
I think it's a bad hub it, axles a loud roaring noise and vibrates and there's a little play from doing the side to side with the front tire.
Nov 29, 2024 at 7:56 AM
  • 110,244 POSTS
Often, a faulty hub bearing will make a roaring/humming which seems to change based on speed. Try this and let me know what you find. See if the sound changes when making turns. When you try this, take notice of the sound and which direction makes it louder or quieter.
Also, take a look through this link and let me know if what you experience mirrors anything in the link:
https://www.2carpros.com/articles/7-common-symptoms-of-a-bad-automotive-bearing-hub
Nov 29, 2024 at 11:28 AM
