Rio JB RPM drop after AC turn on
100,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
WIRSHA
i have kia rio jb hatcback 2006, and i ve already replace Idle speed control with a new one, but idle rpm still drop and sometimes engine turn off or knocking, is that any wiring or something beside ISCV sensor, what i have done :
1. carbon clean
2. replace spark plug
3. replace spark plug wire
4. replace ISCV
thank Q
Jun 19, 2014 at 8:01 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner see if that helps.
Jun 19, 2014 at 11:25 PM
WIRSHA
i have already clean TB and both of side the plate with carb. cleaner
Jun 21, 2014 at 10:31 PM
HMAC300
  • 48,601 POSTS
I can't say anything about the knocking as I can't hear it, but scan for codes and check fuel pressure with a gauge one will show something.
Jun 22, 2014 at 1:14 AM
WIRSHA
how to check fuel pressure...?
Jun 22, 2014 at 12:21 PM
HMAC300
  • 48,601 POSTS
if in U.s . most major autoparts rent the gauge there shold be a shcrader valve on fuel rail if not it will require adapters.
Jun 22, 2014 at 11:44 PM
