Will 16" rims fit on this car?
20,000 MILES • 3.7L • 6 CYL • 2WD • AUTOMATIC
VALIANT SQUIRREL
I’m trying to get a bit more ground clearance and also the tires are much easier to find.
Oct 1, 2022 at 12:13 AM
  • 55,694 POSTS
They should if you use a low-profile tire. Make sure the circumference of the tires is not much larger than the stock ones.
Oct 1, 2022 at 4:40 AM
VALIANT SQUIRREL
Okay, thank you. I was considering slightly wider in the rear for better traction, but I wasn’t planning to go crazy. I prefer to keep my car looking as factory correct as possible. Mostly I’m just wanting more affordable tires and to make the car sit just a couple inches higher so I stop hitting things with the undercarriage.
Oct 1, 2022 at 11:04 AM
