The rim (cover?) is tucked into my cars tire. is there a way to untuck the rim without going to a professional? And is it damaging my tire?
May 4, 2020 at 11:14 AM
✓Experienced Mechanic
I think the best thing to do is get a picture of what you are dealing with and we will be able to determine the best course of action and answer your questions.
You can just post it using the link below the text box. Thanks
May 4, 2020 at 12:35 PM
RAKEL HETLAND
MEMBER
I thought I already added one. Sorry
Image (Click to enlarge)
May 4, 2020 at 2:29 PM
That really helped. Thank you. That appears to be a tire that is going flat or at least low on air. Can you check the air pressure?
What appears to be happening is when the tire gets soft or low on air pressure it spreads out and starts making contact with the hub cap. I suspect putting air in it will resolve the issue. Thanks
