Right turn signals flashing rapidly
180,000 MILES • 6 CYL • AUTOMATIC
BOYD BELMORE
The right turn signals started blinking rapidly. There are no burned out bulbs. The left signal works normally. All other lights work properly.
Dec 21, 2017 at 12:17 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That usually happens when a bulb or wire is shorted out causing excessive current and heat, thus making the turn signal flasher open and close faster. Are you sure even though no bulbs are burnt out, that they all are actually working, even if flashing fast, make sure at least that they all are working. That includes the indicator on the instrument cluster, also.
Dec 21, 2017 at 1:14 AM
BOYD BELMORE
Yes, The indicator on the instrument panel is flashing as well as the light itself. All bulbs are working and all signal lights are flashing.
Dec 21, 2017 at 3:36 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I honestly have no idea then why they are flashing fast.
Dec 21, 2017 at 3:43 AM
BOYD BELMORE
Thank you for your honesty and not giving me some BS answer.
Dec 21, 2017 at 3:51 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Perhaps you have a bulb that is just bad or weak but still working. either try swapping them from side to side and see if the problem switches to the left side or just replace all the turn signal bulbs on the right side.
Dec 21, 2017 at 4:20 AM
