Right turn signal issue
100,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
FORENSICS
  • 112 POSTS
Hello and thanks to all who read.
My right turn signal does not function; the front right bulb doesn't come on at all and the back right comes on solid without blinking.
When I click left the left side works and when I turn on the hazards all 4 come on and work properly as they should.
May 3, 2020 at 8:07 AM
  • 55,732 POSTS
This sounds like the turn signal switch needs to be replaced. This guide will help you check for power through the switch to confirm the issue:
May 4, 2020 at 5:11 AM
