Right turn signal failure?
20,000 MILES
MTHARDING
What is the comparable replacement for the outer turn light? Required LED light.
May 31, 2025 at 10:01 AM
  • 55,732 POSTS
Do the front and rear blinker light not work or does the system work, but you have one or the other out? If the right side is not working, I would check the fuses listed in the images below. This guide can help:
I need more information to help you. Check out the images (below). Please let us know what happens.
Jun 1, 2025 at 3:28 AM
