blinker wire diagram or color code for hot and ground
8,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
NISARAHMED1965
  • 6 POSTS
2013 camry se need to know the ground wire color for passenger side signal light hook up , i get hot wire but like to hook the ground.
Jan 12, 2015 at 10:45 AM
HMAC300
  • 48,601 POSTS
turn signal for rear is lt blue and for lights it's green
Jan 12, 2015 at 10:09 PM
HMAC300
  • 48,601 POSTS
ground is brown at light
Jan 12, 2015 at 10:10 PM
  • 110,251 POSTS
Looking at the schematic, both sides provide power through a red wire. The ground appears to be a white / black wire. Check the white / black for continuity to a known ground.
Jan 12, 2015 at 10:17 PM
NISARAHMED1965
  • 6 POSTS
I am adding a arrow light to my side mirrors at 2103 Camry Se, and i did the driver side with front wire color , but i have problem with passenger side i did all the step up mention my friends and every time hook wire relay of car right stop to respond and no sound no nothing than i touch mostly blue wire did not working .
Now one of the person he hook and it working fine but it miss place like when i press brake the right side signal light stop and when i release brake it work fine, please in any one knows answer or picture will help mostly wire i cut and try to find but not any easy way will glad thank you.
Malik
Jan 13, 2015 at 8:26 AM
  • 110,251 POSTS
Okay, now that I understand what you are doing I may be able to help more. Have you run the power supply wire from the signals to the mirrors? How have you provided a ground?
As far as the wiring schematic., I can't copy and paste it for you, but I can answer specific questions you have.
Jan 13, 2015 at 10:43 AM
NISARAHMED1965
  • 6 POSTS
Yes the arrow light working fine by it self and so do the wiring ! but i think the person it self put the ground with back brake light , the signal of car work fine but only the arrow light stop blinking when you push brake.
I just need to know what color the wire i need to attach with what color in 2013 Camry Se, 2.5 engine , I try all of wire right side of car door panel and there is nothing on right side , i did get 2 wire for the driver side signal and right away it work fine and nothing problem so far but the passenger side the tech screw up , i am worry because i did not need more problem, car is new and warranty but you know how dealer are ?
Please inform me what wire i add to the door panel where i can get get ground, the wire of arrow with it self when i hook with hot wire right away i check the tester the hot is GREEN power and other wire of arrow is getting power too , than i touch the ground with white/black wire the relay stop of car to respond and no signal light, so i stop car for few moment and pc of car with it self re set and start again , i am really up set that which wire i connect so get signal work with self ?
Malik
Jan 13, 2015 at 11:13 AM
  • 110,251 POSTS
Since my schematic is showing a white/black wire as a ground, that is what I would suggest. However, since you know the correct power supply is used, just run a new (separate) ground for the new signal lights.
Jan 13, 2015 at 11:26 AM
NISARAHMED1965
  • 6 POSTS
Ok i will try this Friday 16th of Jan and will let yo know and also i am going to send you the pictures ok.
Any way thanks for respond and help it help me .
Take Care
Malik
Jan 13, 2015 at 11:38 AM
  • 110,251 POSTS
Glad to help.
Jan 13, 2015 at 9:18 PM
NISARAHMED1965
  • 6 POSTS
Expert you really perfect and good , i follow your step and i get it thank you i wish i can pay you 50$ which i payed to that stupid , any way its a part of life , best of luck and thank you.Jacobandnickolas
Jan 17, 2015 at 1:35 AM
  • 110,251 POSTS
Excellent!!! I'm glad you got it fixed. Let me know if I can help in the future.
Jan 18, 2015 at 10:01 PM
NISARAHMED1965
  • 6 POSTS
2013 Camry Se , i add twitters front while adding it i think i short wires at passenger side, i cancelled the twitters now found it rears speakers which i added new working fine front speakers driver side working perfect only only the passenger side speakers at front dash one and at the foot not working .
Please give me advice what to do ? because i checked all the fuse OK, i see the wring are perfect i add ground it working but making too much noise .
Jun 26, 2017 at 4:38 AM
  • 55,837 POSTS
Please post your question here
Cheers, Ken
Jun 28, 2017 at 10:52 AM
