Drivers side is good. Have replaced all 3 bulbs, anything 'light' fuses... Inside under dash and motor side, found 2 wiring harnesses, and still nothing. Didn't think it'd be the brake light switch or the multi function switch due to drivers side working normally. Even pulled apart the steering column and played with the wires to the hazard switch. No loosie goosies. Now at my end... Help would be much appreciated. And thanks in advance.
'L'
'L'
Dec 3, 2019 at 10:23 AM
