Right rear lights not working properly
130,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
DENNIS.BOYD
  • 5 POSTS
The brake light when stopping goes off , when I turn blinker on right upper turn signal and backup lights and license light and driver side blinked and back up light blinked. when operating drivers side taillight only works perfect.
Oct 9, 2020 at 2:20 AM
  • 110,248 POSTS
Based on your description, the first thing I would check is the wiring at the rear electronic control module. That is the one thing that ties the lights you mentioned together.
If you look at the attached pic, I highlighted the wires which go to the module. Check to make sure none are crossed, shorted, or damaged in any way.
Also, I will need to know if you have a factory trailer tow package. There could also be a short in the wiring to the trailer module or the connector itself.
Let me know what you find.
Oct 9, 2020 at 12:58 PM
DENNIS.BOYD
  • 5 POSTS
There is no damages to wiring looks like new. I did remove the solenoids in trunk one at a time no change.
Oct 10, 2020 at 4:23 AM
DENNIS.BOYD
  • 5 POSTS
I disconnected battery. To in stall factory OEM bulbs , hooked battery backup won't start, the battery has plenty of juice.
Oct 10, 2020 at 6:59 AM
  • 110,248 POSTS
Is the issue with the lighting or a no start? Or, is it both.
Does the starter engage?
Oct 10, 2020 at 10:05 AM
DENNIS.BOYD
  • 5 POSTS
The lights are working fine now, it was a fuse located in the trunk, one thing about this car it started up the minute you turned the key. I replaced blow fuses there was 3. Now it won't start. has lots of cranking power . No problem with battery. I double checked all fuses.
Oct 10, 2020 at 11:23 AM
  • 110,248 POSTS
What three fuses were replaced? Also, do you hear the fuel pump turning on when you first turn the key?
Take a look through this link and see if anything helps:
Let me know. Please feel free to ask questions if you have them.
Oct 10, 2020 at 12:24 PM
DENNIS.BOYD
  • 5 POSTS
The car and light's work perfectly now. I had removed the relays in trunk to see if they were okay. I went on line to find diagram for relays , the one that said fuel diode , I put it in wrong spot. I noticed on diagram there was a space between it and a relay and I put next to it. But I want to thank you so much for your advice and time . I'm lucky I got it solved. have a good night.
Oct 10, 2020 at 1:35 PM
  • 110,248 POSTS
You are very welcome. I'm glad to hear you got everything taken care of. Please feel free to come back anytime in the future if you have questions.
Take good care of yourself.
Oct 10, 2020 at 1:39 PM
