right rear drops
136,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RAILROADY
I have replaced the bag, solenoid and compressor, and it still drops, left rear stays up. what else could cause this problem?
Mar 22, 2020 at 4:43 AM
Good afternoon,
Did you replace the vent solenoid with the airbag?
Did you drop the car all the way to the ground and then start it up? I have seen where the bags are replaced and damaged when dropping it down and it hits the ground. The bag gets pinched and will not hold air.
Mar 22, 2020 at 5:00 AM
