Right pull when driving
180,000 MILES • 6.0L • V8 • TURBO • 4WD • AUTOMATIC
PATRICIA COX
When braking pulls to the right. Replaced calipers and brake lines on both sides. Left Hub gets hot. Any idea what to look at to resolve?
Mar 21, 2018 at 12:18 AM
  • 55,748 POSTS
It sounds like you have a brake flex line that has collapsed internally. Here is a video to show you what you are in for when changing the line out. I would do both front FYI.
https://youtu.be/1Prs_coIuCg
It is not on your car but you get the idea which is the same.
Check out the diagrams (below).
Cheers, Ken
Mar 22, 2018 at 4:20 AM
PATRICIA COX
Thanks so much Ken.
Changed the brake lines (both) and now seems fine.
Thanks for your help.
Mar 22, 2018 at 9:49 AM
  • 55,748 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Mar 23, 2018 at 2:50 AM
