Right motor mount nut
180,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
RICKOSHEA
Exactly what size wrench is used to remove the 5 sided nut from the right motor mount. Thank you
Mar 29, 2018 at 12:22 AM
  • 55,770 POSTS
That is not a nut it is a welded boss that is meant to be part of the mount it will not come off, loosen the bolt from the other side. Please send pictures if this does not make sense.
Cheers, Ken
Mar 30, 2018 at 4:45 AM
